1949 M-68 (F-3) Modern aftermarket rims
Brakes
Instead of swapping the rear axle for one that looks nothing like the original, you can just swap the brakes. Backing plates, shoes, drums, and e-brake hardware from any F-250, 1957 through about 1975 will bolt right on your stock rear. Just make sure you get the 12 1/8" x 2" (most common) setup. Now you can use 1948-66 F-2/F-250 16" wheels, and your stock hubcaps will fit. If you get them from a 1970's truck, you will also get the self adjuster setup.
Chuck
Chuck
Chuck, this backing plate out swap option makes it easy to keep the Timken. My issue with doing this is the tallest 16" tire I could find is about 32" tall. (235/85-16)
Isn't the stock 4.86 gear with the stock 34" tall 7.50-17's a 45 MPH truck? How is it with a 32" tall tire?
I would have liked to keep the stock rear but, I'd like to go a bit faster. What options are out there to address this? Overdrive?
Scott
Scott
The 48 F2 I sold had a bad rear diff so I sold it with the Timken from my 52 F3. They both needed new drums which I "thought" were near impossible to find.
Had I known I had other options when I made that decision I might be calling you for the 4.11's.
Right now I have a 72 F250 Dana 60 with 3.73's. Running the F2 shock mounts and 16" innies with stock hub caps. I think the Timken looks better.
Live and learn I guess. Thanks for the reply Chuck.
1973/75 F250 4WD, front only. These 4WD's rear drum brakes are 12" x 2 1/2."
Self adjusting brakes were introduced in 1966 F250's with 12" x 2 1/2" brakes. In 1967 F250 2WD/4WD with 12 1/8" x 2" brakes.
Send a PM to 1950FordF3. He is the guy that posted the pic and says they clear the 14" drums.
I didn't post the link correctly. Trying again. Its on page 4 "1950F3 what 8-lug pattern fits" https://www.ford-trucks.com/forums/7...tern-fits.html
