1998 F150 XLT 6.5' Flareside Custom anchor point/tie downs dilemma - Ford Truck Enthusiasts Forums
Old 03-23-2016, 06:08 PM
BRONC-OH BRONC-OH is offline
BRONC-OH is starting off with a positive reputation.
Well, I got a good deal on a 1998 F150 XLT extended cab, 6.5' flareside (stepside) bed pickup. I bought the truck to use as a truck meaning I need to haul stuff in it.
I had not had a stepside since the 70's and was very disappointed when I finally got to looking at my new/old truck in more detail. Fiberglass fenders over a metal box. No stake pockets, long plastic rail caps that snap into the fiberglass.
The 4 low mounted anchor points inside the bed are OK but are somewhat limiting, especially if you are hauling tall items. I need some rail-top or just inside the top of the rail anchor point options.
I have been searching all over the web for a perfect solution. Maybe I just haven't been searching long enough. I just can't believe that nobody offers a good aftermarket solution made specifically for this truck. There had to been more than just a few made and you would think one or two of them were actually used for hauling a variety of items.
Before I start cutting plastic and drilling holes all over the place, I would appreciate all suggestions on high mount anchor point tie-downs. How did you solve this problem? Pictures would be great too.
Thanks in advance!
Old 03-24-2016, 10:07 AM
steve(ill)'s Avatar
steve(ill) steve(ill) is online now
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
I took two of a 3/8 inch stainless eye bolt and drilled a hole down from the top, thru the plastic top rail, thru the steel rail and put a big washer and nut under the rail. They are mounted about 12 inches from the cab wall........... this will allow me to have high up tie points when hauling a stove, refrig, etc.
Old 03-24-2016, 10:32 AM
first today's Avatar
first today first today is offline
first today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant future
Tractor supply sells a tie down track that mounts under the rails on the side walls. The tie down points are adjustable in the track.
Old 03-24-2016, 11:40 AM
Been all through the Tractor Supply web site, can't find it. Do you have a link or specific item?
Old 03-24-2016, 05:19 PM
You are right. I looked and did not see them. I did a search and found them online. Here is a link. http://r.search.yahoo.com/_ylt=AwrB8...yYY_X9rEKIJhs-
This looks better than what I saw at tractor supply.
Old 03-28-2016, 10:44 AM
dsgreene71 dsgreene71 is offline
dsgreene71 is starting off with a positive reputation.
E Track might work for bed box?
I have had good experiences using the "E-Track" type components. I like the availability, (Harbor Freight, Northern Tool, etc...), and there are a lot of choices for the tracking, (horizontal, vertical, single slot, multi-slot by length...) and anchor types, (rings, ratchet strap, hooks, etc...).
I have found that most E-Track stuff is reasonably priced, highly versatile, and up to heavy-duty loads.
Sorry if this sounds like a sales pitch...not my intention, I just thought it might be a good solution to consider.
For reference, here are some links to product pictures and explanations...
Accesories Trailers | E Track | Straps | Van Trailer
https://www.google.com/search?q=e+tr...bih=1004&dpr=2
Hope you find what you need,
Cheers
Old 03-31-2016, 03:30 PM
PROBLEM SOLVED!
I just installed 4 of the 5" Core Trax tie downs.
I cut out spaces for them on the inside edge of the plastic rail caps with an oscillating tool. Cut a piece of 1 x 1/8" aluminum for backing behind the bed steel instead of the supplied round washers. I figured that would provide better support. Installed with supplied 1/4" screws and locking nuts.
Decided to leave the center indentions empty for now, but I do have the 5" Core Trax to put there if I want to later.
Looks pretty nice and unobtrusive. Satisfied so far.
Where are the Cargo Tie Down Points on the 2016? Erzebet 2015 + Expedition & Navigator 0 11-13-2016 02:31 PM
SuperCab rear doors won't open. Cable / Latch broken bigtexan99 1999 - 2003 7.3L Power Stroke Diesel 32 09-18-2016 05:59 PM
Bed tie downs / anchor points iwmoose 2009 - 2014 F150 4 03-22-2016 12:55 PM
A little help on installing a topper please. BRONC-OH Ranger & B-Series 2 07-26-2013 05:29 AM
Anchor Points? super fly 1987 - 1996 F150 & Larger F-Series Trucks 4 05-08-2013 07:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
