I'm also going to check on that dual battery set up. It was a bolt in kit with no modifications needed? Ddi you mount the plow solenoid to the second battery brackets? My current solenoid set up is right where you put that second battery.
The top of the kit has a top flat spot to mount stuff as you can see in the pictures but I attached mine to the flat spot of the body facing the front of the truck.
Just got the battery tray, very easy install, I would have never found it without this thread.
That's great and the reason I started this thread. But to be fair there was also a thread on it buried here somewhere which is where I found it. The Blue Sea setup I've used for years on my off road truck, boats, ATV, etc. and have found it to be pretty much bulletproof and completely automatic. While there are other systems out there, even cheaper, I'm a big fan of overkill and like that it was over designed for marine use where there is much less forgiveness for failure.
