Code Help!
03-23-2016, 05:15 AM
FTE-Spread The Knowledge
Code Help!
Got a few codes and wondering what is up. 96 F-150
P1506
P0141
P0171
P0174
P0385
Thanks for the assistance.
03-23-2016, 08:40 AM
Assume those are for your 2002 F350 in your signature?
03-23-2016, 08:48 AM
Quote:
Originally Posted by
rla2005
96 F-150...
03-23-2016, 11:19 AM
Looks like the P1506 could cause the next three codes (P0141, P0171, P0174) but not sure about the P0385 being associated with it, any ideas?
03-23-2016, 11:51 AM
Diagnostic Trouble Code (DTC) P0385 indicates that Self-Test has detected a Misfire Detection (MD) Sensor circuit failure.
Possible causes:
-- MD circuit open.
-- MD circuit shorted to GND.
-- MD circuit shorted to PWR.
-- SIG RTN open.
-- Damaged MD Sensor.
-- Damaged PCM.
03-23-2016, 11:56 AM
Whitey Ford
P1506 is a symptom as well as P0171 & P0174. I suspect you have a vacuum leak.
Code P0141 indicates a problem with the O2 sensor heater circuit.
03-23-2016, 02:33 PM
rla2005
Possible causes:
-- MD circuit open.
-- SIG RTN open.
-- Damaged PCM.
I have read that a vacuum leak or intake gasket leak can also cause this issue and the lean bank codes. I will complete this thread when we figure it out. Smoke (brake cleaner) test next.
03-23-2016, 02:36 PM
rla2005
Thank you. Looks like they all could be related. With an intake leak can an O2 sensor code throw with the lean running condition?
03-23-2016, 03:37 PM
Whitey Ford
Yes
Any unmetered air will usually trigger a lean code.
03-23-2016, 03:59 PM
rla2005
Yes
Thank you!
dwrivers
08-22-2005 09:49 AM
triplethreat
02-03-2005 02:02 PM
Leadsled Coupe
05-05-2004 05:34 AM
Billy Ray
01-03-2004 07:57 PM
