Spark plug question - Ford Truck Enthusiasts Forums
Spark plug question
Old 03-21-2016, 04:48 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
Spark plug question
I have my new engine getting ready for installation. The normal plug for the EFI 460 is ASF-42P. I have raised the compression to 9.23:1, the question is, should I drop back one heat range to ASF-32P?
Thanks!
Old 03-22-2016, 11:05 PM
cbakker's Avatar
cbakker cbakker is offline
cbakker is starting off with a positive reputation.
I thought higher compression generally meant hotter combustion temps? I wouldn't be worried about that compression level anyway. My build ended up about 9.3:1, and I'm running auto lite copper 25's. I was always told the platinum plugs were a waste of Mamet, so I never ran them and have had good luck with copper. Did you rebuild your EEC-V motor?
Found this gem for plug reference:
http://www.ford-trucks.com/forums/11...parkplugs.html
Old 03-23-2016, 07:54 AM
This is the short block from the donor truck, a 1990 F-250. We rebuilt that at .030 over, using the 1988-1992 pistons, a Sig Erson cam and everything balanced. The heads are a pair of F3TZs with Scorpion rockers.
The engine in the truck is the original 1986 short block with the top end of the 1990 engine. It is only maybe 8.0:1 compression as a result. The reason for asking, the VECI label for the EEC-V California models call for ASF-42P plugs, I am currently running ASF-42C plugs as that is what the 1990 spec is.
Old 03-23-2016, 07:41 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
Quote:
Thanks!
IMHO, no....because there is not just the CR but the cylinder psi as well that factors into this......and the CR hasn't been raised that much really 9just enough to make it nice). This is fine for the initial start-up and break-in period since you're going to be driving it gently......
because of the unleaded gas, plug color is not going to be a good short term indicator.....once it's broken in, then I would try some gentle lugging to check for pinging.....if there's none, I would just periodically check the plugs and go have fun!
Old 03-23-2016, 07:50 PM
I do plan on adding a knock sensor, my EEC-V can support it so I shouldn't risk damage. Lugging could be interesting, it's coupled to an E4OD.
1989 rebuilt 7.5 with F3TE head spark plug issue lisagoud 1987 - 1996 F150 & Larger F-Series Trucks 7 10-01-2014 09:30 PM
8 new motorcraft spark plugs ,SP-415/ASF32C copper core MI Yeti Ford Truck Parts for Sale 2 09-29-2014 03:26 PM
5.0L "High Output" Engine Listed in 1985 Owner's Manual LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 04-08-2014 10:44 PM
1992 302HO into a 1990 F150 now problem gissmo2 1987 - 1996 F150 & Larger F-Series Trucks 2 03-16-2014 10:14 AM
Difference between ASF-32P and ASF-42P sparkplugs? Anafiel 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 09-27-2012 08:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
