Transmission clicking
Most of the time if TOB and if it has free play when you step on the clutch pedal the noise will change.
I just looked and it looks like you have a hyd clutch so the so called "free play" is not at the fork like the old linkage type so the TOB is in consent contact.
But still if TOB it should change noise when pushed if it was bad I would think.
If coming from the trany and the clutch is working right pushing in the clutch should stop the input shaft from turning so if noise was from trany it would stop.
Next guess is clutch disc and/or pressure plate.
Dave ----
Dave ----
Is there an electric fuel pump bolted to the frame that may have come loose?
You sure it does not speed up with engine speed?
I cant see what may cause the clicking noise to only start when motor is warm (up to temp) and not speed up or slow down with engine speed ie stays the same tempo and be coming from the trany.
Dave ----
Dave ----
Dave ----
Dave ----
Dual tanks? If so, the selector valve is in that area, tucked inside the frame rail on the driver's side. I've never heard of one continually clicking, but who knows.
The valve is spring loaded to the rear tank. If you've been running on the front tank, select the rear to remove power from the valve and see if that stops the noise.
