49 F1 replacement seat?
There's a Sticky Thread right at the top of the first page of this forum called "READ FIRST: 48/60 Forum Tips, Tricks, How To's!" It has links to past threads with many of the most common discussions, including suspension, seats, etc. Many of those are somewhat hidden in a link in the first post of that, https://www.ford-trucks.com/forums/6...-articles.html
Here is a post from the FAQ on seats: https://www.ford-trucks.com/forums/6...ml#post5537364
on
I used a 90 Ranger regular cab bench seat in my 49 F-1. With a little fabrication you can use the original 48-52 F-1 seat brackets. I cut about two inches off the original seat brackets to lean the seat back some. The back is thinner than the original which gives you a little more room at the steering wheel too. It also allows use of the original tool tray. Worked fine.
StevoF1
03-14-2022 06:46 PM
f100 1957
10-17-2013 07:21 PM
