H-Pipe Crossover?
H-Pipe Crossover?
Some of you may know had Rams horn manifolds and Porter mufflers installed in my '64 last fall with "true dual" 2" exhaust tubes extending all the way out exiting at the bumper.
Sounds excellent though lately starting at, and around 65 mph, it has a drone in the cab or a kind of resonance, while it's OK on a trip across town I definitely would not want to make any kind of a road trip more than a few minutes with it like that because it's loudest exactly at the speeds where a long cruise would typically be at.
Would installing an H-pipe or crossover tube reduce the drone or volume at these higher speeds? I've read they "mellow out" the exhaust and provide more power. Hm.
Well I wondered about that, but there's just this point of resonance I guess you'd call it, that's why asking about a crossover. It's real well behaved otherwise except at those 60-65+ highway speeds.
Well it runs and sounds great. But I need my hearing or, at least don't need tinnitus anyway. It needs a road trip anyway, to burn all the carbon out.
The old single exhaust terminated (eventually, ha ha) before the rear wheels. Well I had it all figured, that the dual pipes running another several feet and straight out the back would make the cab pretty peaceful at highway cruise. Oops. Will have to try a crossover, if the drone goes away it will be fine I think.
I'm assuming your mufflers are well under the bed and away from the cab.
The H - pipe will improve performance but i doubt it will help with the noise.
Sorry, but if your looking for a little less sound, the only way your going to achieve that, change your muffs - as was suggested. The ones you have,,, make noise.
My truck has true duals right now, I've got headers that collect at 3" then reduced to 2 1/2" and flowmaster super 44's and after that the pipe is reduced down to 2 1/4" (it was all free pipe). I'm running a 292 in my truck with that exhaust and it's loud, even at idle. Sounds very aggressive. Mine exhaust drones a bit, but it's nothing to bad. Maybe you could try the mufflers im running or something similar
My truck used to have those headers and about 3 ft of pipe to the mufflers and then nothing after, you better believe it would rattle your teeth because it was so loud haha a trip on the highway was like standing next to a rock concert. Your ears would ring for 20 minutes afterward.
