western junior mirrors
Old 03-20-2016, 09:58 PM
1browski's Avatar
1browski
1browski is online now
According to some old threads I have type 3 western junior mirrors on my 70SCCS.
I am looking for some suggestions on what type of material to use beneath the clamps on the vertical bar to tighten up my mirrors. When on the highway, the air moves them until I cant see with them. The only thing I could think of to use was some heavy electrical tape but I would like to stay away from that. Any other alternatives that anyone is using would be good. I couldnt find anything from just looking at mirrors.
Old 03-20-2016, 10:17 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Strips of 320 wet/dry sand paper - folded back on itself.
Old 03-20-2016, 10:18 PM
gangstakr's Avatar
gangstakr
gangstakr is offline
Change out the clamps and bolts. I believe you can get them at any hardware store. New clamps, new bolts with acorn nuts are available. Measure the diameter or take a clamp with you, get one size smaller if needed.
Old 03-20-2016, 10:46 PM
pat67shorty's Avatar
pat67shorty
pat67shorty is offline
Pieces of tire inner tube.
Old 03-20-2016, 10:56 PM
farmallmta's Avatar
farmallmta
farmallmta is offline
Thumbs up
If your wife won't let you steal the inner tube out of her bicycle tire for mirror clamp shims , cut a length of black Gorilla-brand tape the width of the mirror clamp. The first layer goes sticky side out around the upright below the clamp in question. The remaining layers go sticky side in. You keep wrapping until you've accumulated enough thickness to allow the clamp to snug tightly when you easily slide your self-created "inner tube" under the loosened clamp. Then snug the clamp and you're done.
A bonus is that the shim you make from Gorilla tape won't gradually compress and eventually start slipping again like the rubber inner tube material.
Old 03-20-2016, 11:26 PM
1browski's Avatar
1browski
thanks for the replies. I like the combination of tape and inner tube. I think I will also add new nuts and bolts that are not rusted out. If I remove the mirrors all the way from the door, I guess i should put a piece of rubber between there as well.
Old 03-21-2016, 08:52 AM
HIO Silver's Avatar
HIO Silver
Originally they were equipped with hard plastic "seals' btwn the brackets n sheetmetal....
Old 03-27-2016, 10:32 AM
Driller6309's Avatar
Driller6309
Driller6309 is offline
I have a 1970 f 250 camper Special and would like to find a place that has original mirrors for it. Any ideals?
Old 03-27-2016, 12:47 PM
HIO Silver's Avatar
HIO Silver
Be more specific. What mirrors ya lookin for?
Old 03-27-2016, 12:58 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,597 Likes on 1,443 Posts
I second that emotion!
I am using that on my 70 F350.
54321toz
01-29-2018 12:01 PM
michael a
1947 and Older Ford Trucks
08-19-2015 07:10 PM
quinletc
09-10-2014 08:30 PM
mcguyver
02-03-2011 02:54 PM
Skip1970
12-24-2009 03:40 PM
Quick Reply: western junior mirrors
