Loose Rocker Arm(s) ??
Old 08-12-2003, 07:18 AM
Katmandu2's Avatar
Katmandu2
Katmandu2 is offline
Arrow Loose Rocker Arm(s) ??
How common is it for the 4.9L Rocker Arms to work loose ??
Old 08-12-2003, 04:58 PM
kevin122's Avatar
kevin122
kevin122 is offline
htey have pressed in stud so it is possible, but i've also seen worn rocker arms cause some problems
Old 08-12-2003, 05:51 PM
Silver Streak's Avatar
Silver Streak
Silver Streak is offline
The later model EFI 4.9's don't have rocker studs, they have a pedestal that bolts down to the head. I don't think I've ever seen one loose. They are either tight or the bolt is broken off.
Old 08-12-2003, 10:34 PM
serving_time's Avatar
serving_time
serving_time is offline
I had an older one with studs, and I had a problem forever with 2 of the rockers working loose. Just try to get them set and jam the adjuster nut and the lock nut togther as tight as you can
Old 08-13-2003, 02:59 PM
Katmandu2's Avatar
Katmandu2
What year did Ford change from the Studs to Pedestles ??
revans9295
03-30-2013 08:08 AM
deve
03-18-2011 02:14 AM
seafire
05-03-2010 11:40 AM
Nickiboy
05-11-2008 10:03 PM
1975Ford
09-25-2006 08:44 AM
Quick Reply: Loose Rocker Arm(s) ??
