460 fuel pressure
#46
#47
I don't feel like searching through the thread on my phone, but if it's speed density it won't be very easy to find someone to tune it...Need a different computer and a gm 3 bar map sensor for the boost, not impossible but it's just been too long since these have been relevant; not enough people are familiar with the setups required.
#48
#49
on
#50
#51
I WANT to know what my fuel pressure is. The 460s fuel "log" does not allow for adapting a fuel pressure sender, that is why I went with the adjustable regulator which has a port.
YES, I know a small block fuel "log" you you can remove the schrader valve fitting and put the sender there. But the 460 one is welded in place
#53
#54
#57
Earlier model 460's (like my 89) will take the 3 hole BBK 1706. Nobody that sells them say they will fit a 460, but lots of things fit things they are not supposed to. Probably some emissions law crap that keeps them from saying they will fit.
On a side note, I haven't had very good luck with my BBK's. Won't hold pressure after the engine is turned off and you can't get a rebuild kit that fits. I'm going to try a different brand but I'm not sure who yet.
#59
