One cavete, The trim pieces are aluminum but they are coated with a hard aluminum anodizing. If you go through it the aluminum underneath wont stay shiny as easily. You probably will go through it if you have a lot of pitting etc. Once you go through it in some areas you'll have to go all the way or you will see the difference. You'll just have to polish it more often.
Noted. Fortunately I'm one of the weird ones that does not mind polishing even hard duty equipment. "A spotless engine room is a happy engine room" same goes for work trucks.
Oops, I dropped a reply onto the other thread that may seem out of context.. thanks for the info. It's much appreciated.
no worries, glad it could help. As other poster states, unless your clear it or something of that nature. You will need to touch it up once a year or so..
I do. I've been fishing in Alaska since the early '90s. I'm pretty **** retentive about keeping equipment in the best order I can manage. Makes for fewer breakdowns, easier assessments when something does break, and smoother Coast Guard inspections.
Aye, she's a beaut. Well met. I have one or two more years left at most in the Bering, already an old man in a young mans game. Then it's most likely tugs for me too.
Axidjw, I got a small test piece by your technique, and it is impressive. Score!
