I just installed a new fuel pump about a month ago in my Excursion (V10) and today I started it in warm weather and it was missing real bad and did not get better when it got hot. The fuel pressure is 30 psi idling and about 25 psi after you get the RPM's up. This seems pretty low to me. What should it be? Where is the fuel pressure regulator located?
