steam and water comong out of intake
My truck over heated and I now have a looks like a pin hole leak next to the front injector on the left side looking at it. I have used sealers and it does not work. Water pools around the injector. Does this sound like a cracked intake housing? I have done many repairs but this is something I'm not sure I want to do. I can get a new intake setup for 160.00 on rock auto but ford would be in the 300 or more just for the part. Advise?
you have a blown o-ring gasket seal on the crossover line bolted to the bottom of the manifold
https://www.ford-trucks.com/forums/8...d-on-5-4l.html
yes it squirts up... The lower crossover line is bolted to the bottom of the manifold and sealed with an o-ring, not a gasket. The plastic groove in the intake manifold distorts and blows out the o-ring... it can squirt up.. Water around the injector and shorting out the #1 or 2 plug is a common problem.
2001 5.4 Had similar issue. Leakage causing #1 misfire. Intake manifold had a small crack that I found after pulling it. They can also warp and can be epoxied in some cases. I went with the $160 after mkt intake. Takes about two days labor. Might as well replace plugs, o rings on injectors, serpentine belt, tensioner pulley, and coolant while you're at it. Get a couple cans of throttle body cleaner too. Clean the idle air control valve b4 putting it back together. Inspect all those vac hoses too. There's a fitting on the back of the new intake where the egr hose connects that snaps on. Be sure to put the o ring on the snout b4 you insert it into the intake. The OEM intake is solid and does not come apart.
Pond
03-19-2021 07:29 PM
michbol
11-14-2011 01:25 PM
