tuning software - Ford Truck Enthusiasts Forums
tuning software
Old 03-13-2016, 10:14 PM
rock2610d's Avatar
rock2610d rock2610d is offline
rock2610d has a good reputation on FTE.rock2610d has a good reputation on FTE.
tuning software
Has anyone ever used:
Special Forces
I am putting a Kenne Bell kit on my V10 and wanted to know if this is a good option?
Old 03-14-2016, 11:27 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
That is stupidly dirt-cheap for a customized tuning package.
SCT's software is (list) $349 plus you need a tuner like an X3 (or X4?) to do the actual flash.
The Special Forces thing looks like it has a "chip" you plug into the PCM like the old days. It sounds like you would have to remove the chip every time you want to change the tune, plug it into the "burner", program it, and then plug it back into the PCM.
The SCT way means just plugging the X3/X4 into the OBD-II port and flashing.
Old 03-18-2016, 03:02 PM
bluetorp bluetorp is offline
bluetorp is starting off with a positive reputation.
I've never even heard of that company, and what I saw/read on their website doesn't exactly fill me with confidence. Maybe it's a great product, but I personally wouldn't take a chance on it.
I've done a lot of tuning of LS engine vehicles using HPTuners, which I can't recommend enough. Great software and support. They currently support 05-16 V10 Superduty vehicles. If yours is older than that, I'd look into going the SCT route. I've never personally used their software, but I haven't heard anything bad about it. They're well-respected.
Old 03-18-2016, 03:05 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
Quote:
Special Forces
What year is your V10?
Old 03-18-2016, 03:25 PM
rock2610d's Avatar
Its a 2000
Old 03-18-2016, 03:27 PM
MisterCMK's Avatar
Avid Winter Hater
Check with moates.net and see if they know if anybody has definitions for the 2000 V10. You can use a Quarterhorse with that truck.
Old 03-18-2016, 03:49 PM
rock2610d's Avatar
Thanks I will check.
Anyone find it odd that both SCT and Delta Force are in Sanford FL?
Old 03-18-2016, 04:27 PM
rock2610d's Avatar
Also want to wire in a WBO2.
Anyone know if there are any available ports on ECU to tap in a WB.
I was thinking since my excursion does not have EGR, maybe the ECU has a port for EGR I could use.
That way I can log A/F ratio via ECU.
Plus, my talon has a MAP sensor that I replaced with one that can read boost. Anyone know if the V10 has that?
Old 03-18-2016, 04:56 PM
MisterCMK's Avatar
Avid Winter Hater
With the QH you can use a wideband and it doesn't have to be tied into the ECU.
My Mustang uses the EGR valve position to connect the wide band.
IMO the best solution would be to get a QH and BinaryEditor/EEC Analyzer and an Innovate Motorsports LC-2. You will need the proper licenses for BE to connect to the QH and the LC-2 but the logging should be pretty seamless after that.
You don't really need to log boost unless you want to. The Ford system is mass air based so the actual manifold pressure doesn't really matter since the ECU knows the mass of the air rather than looking it up based on the VE tables.
I would like to log boost on mine and IAT after the blower (my IAT is after the charge air cooler) so I was looking at the LMA-3 since it has the MAP built into it. Might be interesting to see the air temp before and after the cooler.
Make sure you scale your tables so you never peg them. Once you get the MAF curve dialed in you should set it up so you have plenty of head room - makes it easy to change the pulley and throw more boost at it. I want to say my tables go out to 160% LOAD and I am only hitting 130% or so as it sits.
Most of your time is going to be spent dialing in the MAF curve. Don't try and tune around a MAF curve that isn't spot on.
Special tool? MikeB 88 Ranger & B-Series 2 12-04-2015 08:24 AM
American Force AFZ142 Ford 05-13 F350 Semi Truck Wheel Adapters New Set of 4 vt4cam Ford Truck Parts for Sale 0 11-25-2015 12:52 PM
hydraulic clutch line problems jdub2178 1987 - 1996 F150 & Larger F-Series Trucks 1 06-02-2015 05:49 AM
G force chip ramhunter5877 2004 - 2008 F150 4 05-13-2015 06:17 AM
Radius arm bushings don't fit? ErrorS 1978 - 1996 Big Bronco 9 10-16-2010 02:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
