How do you find a battery leak?
The 'occasion' is the harder part of the issue.
What is the 'occasional' interval?
I could be the alternator but then it would usually not be of an occasional nature and easy to test for.
Otherwise the 'drain' needs to be there to see it when testing.
Normally there is a small drain that is normal from the computer memory and any other equipment that has to maintain memory or a delay time after ignition shutdown..
Basically you need to look at the baseline normal drain to see when the extra drain is occurring so you can see when you open the circuit that is causing the extra drain to see a reduction.
The alternator will cause various drain intervals from a 'leaky' rectifier stack.
What that means is the alternator will still charge normal but allow drain to ground through the faulty stack to ground.
Depending on how bad the leakage is as to how fast the battery will drain down.
If it this a very high drain, the alternator case will feel warm after the motor has cooled as a tipoff. It can be tested for by removing the heavy power cable
very carefully then re-touching it back to the terminal.
If you see a spark it tells you the alternator is leaking the battery back through it to ground.
Bottom line is you have to establish a base line by observing the drain so it can be determined when you find it by such things as removing fuses one at a time to detect the difference in drain.
Good luck.
Good luck.
Gray, you start by removing a battery cable and putting your meter set to OHMS in series between the cable and the battery terminal.. See what current is pulled with key off, nothing running....... wait several minutes for the computer to time out and see what the draw is when it goes into sleep mode..... then follow the directions from Bluegrass.
The easiest and safest way to find the issue is make up a lamp socket assembly and a lamp wattage that just lights to near full brilliance from the drain.
Hook it up in series with the battery lead.
When you find the circuit that is causing the drain and open it, the lamp brilliance will reduce, go dim or go out.
This is a positive and safe way to monitor the progress with out any possibility of damage to a meter.
Be sure to remove the engine compartment lamp so it's drain is not included in the testing.
