Door Clips?
Door Clips?
Where do I get the clips that hold the plastic door panel to the door itself?
I just bought new panels and when I painted the interior I threw out the old ones thinking the new panels came with them.... WRONG
I don't see them at LMC and before I panic I thought I'd check you guys..
Thanks for any help
Thanks for any help
I would hit the local parts store for these. The GM ones are longer than the Ford ones. Make sure you have lubed the window regulator, the track and all else is good, because these suckers will hold a door panel.
Also you can notch the door panel so it fits tighter to the door. The bracket that holds the door pull has 2 bolts heads that hold if off a bit. No worries the arm rest and finger cup cover the notches.
Also get some metal finger cups LMC and make sure the flat back tab is not broken. I sheet metal reinforced mine.
No problem is it all here too, I think it is anyway....lol. https://www.ford-trucks.com/forums/1...then-some.html
Please don't think I'm crazy... my truck had twisted metal as a retainer. Nothing plastic like the pictures you've all shown. It was like a 3" piece of stiff wire (I'd say factory bent) that held the panel to the door.
No need to over think it now that I see clips you've posted. Thanks for the help!!
Yes then you have the factory metal spring clips with a piece of foam...those are tough and great to reuse if you can. But once they are sprung/bent, they do not like to be reused.
Remember that the new push in X mas trees will hold that panel tight. And if you have to pop it back off, you are in for a chore.
I usually use a hack saw blade with a tape made handle and go in between the door and the panel and cut the tree in two. That way you will not break the back side of the panel clip area.
73highboy4x4
08-08-2021 04:21 PM
terceslil
17
03-26-2010 08:50 AM
