Did you put front shock extensions on? Did you put front sway bar drop brackets on? Track bar drop bracket? Flip brake lines at junction block? Any of these could factor in with a incomplete kit and hitting somewhere
Happen only when moving or stationary, or both? I would ask a buddy to turn the wheel lock to lock and try to see/feel all the components on the front end while doing that. Might be a clearance issue that you can spot.
