352 rebuild
Old 03-11-2016, 11:20 PM
hillmstr1's Avatar
hillmstr1
hillmstr1 is offline
352 rebuild
Is it possible to use a 390 crank and rods in a 352 as a stroker motor?
Old 03-12-2016, 12:00 AM
85e150's Avatar
85e150
85e150 is offline
Received 1,584 Likes on 1,292 Posts
Yes, BUT:
With 352 pistons, you will be out of the hole .050, give or take. Too much, as the gasket will only be .040. If the block is decked at all, it will be more.
So you will have to find a 4 inch piston with the correct compression height.
OR, if your 352 block will take a .050 overbore, which it should, you can use stock 390 pickup or car pistons or 360 pistons, depending on what compression ratio you want.
Old 03-12-2016, 11:29 AM
Destroked 450's Avatar
Destroked 450
Destroked 450 is online now
Bore the block .050 over and make a 390 out of it, you have a much better engine.
OrangeJuice
04-08-2010 02:02 PM
Kennewick
11-15-2009 09:57 PM
kkmcclain
03-07-2005 04:03 PM
original67
05-27-2004 09:57 PM
specialz
04-12-2003 11:23 PM
Quick Reply: 352 rebuild
