HPOP OEM or Aftermarket?
appreciate it. my truck is a 95 longbed 4x4. will a pump for a 96-97 model work? my injectors are all stock. I use this truck to haul cattle, pigs and chickens and just want it to run without any bells or whistles. the remanufactured pump I found is by a company named diamonddales. it's a bosch oem and I would buy a new pump but I'm running out of money to put in this truck. If I can get something from Riffraff and get it here by next Wednesday, then I will buy from them based on the reviews I've read in this forum.
Depends if it's late '95 or early '95. I have seen both pumps on '95 model years.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
I appreciate the help. I contacted Clay at RiffRaff about the Bosch and the pumps won't work on my 95, so it looks like I'm going to have to buy a Bosch remanufactured from DiamondDiesel. I found the pump on ebay and wish I could wait for the Terminator but I'm going to put this thing in next Wednesday and can't wait around any longer; my truck has been down for about 2.5 weeks now.
Here's the pump I plan to order tomorrow. Anyone with an opinion whether it's a good one will be appreciated.
1994-1995 7.3L Ford Power Stroke * Reman High Pressure Oil Pump * # HP004X | Diamond Diesel & Turbo Service, Inc.
Thanks for the help
Thanks for the help
Funny, last year it was the opposite. He must have come across a bunch of them
Joey is a sponsor here. His company is terminator engineering.
ended up buying a new pump from the Ford house. I couldn't contact anyone from Terminator and none of pumps I found on-line seemed highly-recommended on this site. I'm a first-timer putting a new HPOP in so if there are tips or advice of what to and not to do, I'd appreciate it.
Gonna be eating canned beans and drinking Keystone for the next couple of months.
#28
This doesn't make any sense. Bosch will have stock pumps for your truck regardless. If he was saying you can't go with an upgraded pump (newer Super Duty style) then that's possible, but you can still get stock Bosch pumps for all the 7.3's.
__________________
#29
The 17º Bosch we swamp fittings on so it will work for the 96+ I think is what he means.
#30
But if he does have the early style pump, you can't directly swap in a 17° pump without drain issues.
__________________
