1996 460 Occassional No Start/No Spark
https://www.ford-trucks.com/forums/1...-thread-2.html
I took the PCM to an old school electronics supply store and had them replace the three capacitors.
Total for parts and labor was $38.
For my situation it was a preventive measure. It has not solved the stumble/miss.
My next step is to test/clean the fuel injectors.
Hope the input helps.
John
I pulled the Spout again today and the truck started right up. I turned it off and replaced the spout and then took it to the quarry for four loads total. It runs and starts well when it's hot, so I'm wondering if I can keep using this trick to start the truck?
edit: the SES light is not on and I don't know how to check for codes on OBD1!
- Shawn
I wanted to ask about this spout part - it's a e53b-14a624-0 but I can't find anyone who sells it online.
The truck just died on me on the road, and I pulled the spout connector out and drove it home (33 miles).
Can I run the truck without this spout connector or do I need to replace it?
- Shawn
- Shawn
Today was the first time that the truck would not run with the spout connector in place.
You mentioned the PCM previously and I looked into it, but I couldn't find a solid replacement in terms of matching the correct engine and tranny.
Is there anything wrong with driving the truck without the spout connector in place?
- Shawn
That's exactly what I thought would happen after I researched it a bit more. I'm going to pull the numbers off the PCM and try to find a match.
I'll update this thread.
Thanks again,
Shawn
#29
I pulled the PCM out and found these numbers:
f6tf-12a650-bsa
Do I need to match all numbers for a new/used PCM? Any recommendations on a source? There is a matching one on ebay for $424.00.
I should also note that the 10 mm bolt holding the PCM plug connector was not even hand tight on there.
Thanks,
Shawn
f6tf-12a650-bsa
Thanks,
Shawn
#30
The F6 along with the BSA are the ones that have to match. All of the PCM's will have the TF and the 12A650 numbers.
One form an auto part store should not cost that much. If you get a used one off ebay after you get it change out the caps as they are getting near the end of their life cycle.
