Not sure if truck is actually overheating
So I've been having this issue recently with my thermostat where it would peg up to being overheating but then would randomly drop down to the normal range or even drop to the below normal range. Today it was completely in the red I was close to home so I got it home opened the hood. The engine didn't seem to be hotter than it normally is. The reservoir has coolant in it, fan is spinning.
One thing that is also weird if it I put the heat on full blast the needle spikes, when I turn the fans off it drops back down. Any ideas? Anything I should check?
on
I think you mean dash temperature gauge when you are saying thermostat, right?
sounds like you have an electrical problem not a cooling problem. But since cooling could be deadly it is best to rule that out first. The thing with your heater controls leads me to believe that you have a short somewhere in your wiring and all you can really do is try and trace everything as far back as you can to check for exposed wire, signs of heat damage, or whatever else it could be. I hate electrical because it is always so 'finicky' like this. however 90% of the time it is a ground issue. Rule out that temp problem and good luck!
2001navigatorbless
10-15-2013 06:27 AM
shelbymay
02-23-2008 08:54 PM
