Removing efi on ford i6 300 1995
It has been discussed endlessly and recently. Search bar is your friend.
Just a summary, there will be more.
Fuel pressure will need to be reduced. Several methods here, not all are good.
You will need to change the intake manifold.
Do you have an electronically controlled transmission? No EFI = big headache.
All this to reduce performance and reliability? Not a good plan.
I've done this
I should say I have used an EFI 300 with a carburator. Mine was a 91'.
It now has a Clifford intake with the EFI exh manifolds and is fed by a 63' Autolite carb. It runs great...It is however in my 86 Bronco.
I did rebuild it, and opened up the hole in the block for a manual fuel pump......I'll follow your progress.
It now has a Clifford intake with the EFI exh manifolds and is fed by a 63' Autolite carb. It runs great...It is however in my 85 Bronco.
if you do this
As a disclaimer I wouldn't recommend removing ANYTHING from your factory approved "95" Ford product.
Pardon my lack of fully making myself clear. From the aspect of whether or not a carb'ed manifold will fit on an EFI head, I correctly answered the OP's question.
It was my oversight to not mention there may be some differences internally.
The same can be said for the 5/5.8L engines but from the perspective of manifold fitment, there is no issue.
