Motor>Cam>Gearing Question
Hey guys I have a 79 f150 with a 302 and currently a 3 speed manual that will be floor converted:
I am currently rebuilding the motor and am looking at a Competition Cams 260H (31-216-2) 212 duration @.500 lift and .447 valve lift.
Will this Camshaft work with my gearing? I assume it will not be an issue with pressed in studs either but just checking. Thank you.
on
With what axle ratio? That cam should work in the motor just fine, I'd say you would want more of a sporting axle ratio to take advantage of the motors powerband which will be 2000-5000rpm give or take. A bump in compression would help too, are you reusing the stock low compression smog heads or do you have something better?
superdutycrazychris
1999 to 2016 Super Duty
06-15-2009 12:10 AM
rancey.sparks
12-08-2004 04:07 PM
