1974 F-600 dump help - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 03-08-2016, 04:27 PM
Brownryan90 Brownryan90 is offline
Brownryan90 is starting off with a positive reputation.
I just bought a 74 F-600 dump. It needs a little work but for what I want to do with it it's great. I am trying to decode the rating plate and am having a few issues. This is what I have so far using the original 5 volume book codes.
I replaced the battery, and starter relay, the truck started and ran when I first picked it up but then wouldn't even click. Replaced the battery and relay and it clicked a single time when the key is turned but that's it. I removed the starter and will be replacing that this week. Am I on the right track?
Old 03-08-2016, 04:28 PM
Sorry, new to this forum and had it posted in wrong thread, any help is appreciated
Old 03-08-2016, 04:42 PM
whomrig's Avatar
whomrig whomrig is offline
whomrig is gaining momentum as a positive member of FTE.
from vinwiz.com
VIN Format: 1961-1980 Ford truck
Decoding: F61DCT06927
Digit
Usage
VIN
Decoded
1-3 Series F61 F600
4 Engine D Unknown!
5 Plant C Oakville ON Truck
6-8 Mod Yr/Mfg Date T06 1974 (Mfg Oct 1973)
6-11 Sequential Serial # T06927 T06927
Serial numbers are sequential per plant
Old 03-08-2016, 05:19 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
F61DCT06297
F61 = F600 2WD (gas).
D = 330 2V Heavy Duty FT engine.
C = Oakville Ontario Canada Truck Assembly Plant.
T06927 = 1974.
Last edited by NumberDummy; 03-18-2016 at 02:51 PM. Reason: Typed Medium instead of Heavy.
Old 03-08-2016, 06:08 PM
Spirit of '76 Spirit of '76 is offline
Spirit of '76 is gaining momentum as a positive member of FTE.
Quote:
Make sure that your battery terminal clamps and connections are clean and secure, good cables, good grounds from the battery to frame and engine block, and the relay is properly grounded.
Good luck!
Old 03-09-2016, 09:48 AM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
And whatever fusible link there is, is good. Move some wires around, they conduct, then hit the key and they break again. Same goes for old wires in general.
If in doubt about anything, make sure the ground from the battery to the engine is good, that the (+) cable from the battery to the solenoid is good, that the wire from the solenoid to the starter is good, and then connect the (+) cable from the battery to the solenoid to the S terminal of the solenoid using a screwdriver and see if it cranks. If it does, and the key doesn't make it crank, you have something wrong between the ignition switch/battery/solenoid.
Old 03-09-2016, 07:56 PM
Ok next question is where do I find parts for this thing. Autozone and Napa haven't been able to find anything for a 74, closest they come are 1980, also what size engine is in this truck? The guy that sold it to me said it had a 391, but looking at the codes it has a 330?
Old 03-10-2016, 06:18 AM
What kinda parts you lookin for? Better off at a Napa with some old guy than those other places. I got some parts listed on my thread;
http://www.ford-trucks.com/forums/99...ml#post9406048
Old 03-10-2016, 10:21 AM
Destroked 450's Avatar
Destroked 450 Destroked 450 is online now
Destroked 450 is gaining momentum as a positive member of FTE.Destroked 450 is gaining momentum as a positive member of FTE.
All 330's I've ever seen came with 2 bbl carb, most with autolite or motorcraft with vacuum governor in the spacer plate under the carb.
All 391's came with holley 4 bbl carb with governor built into the carb and dist.
Most basic parts (points,cap,wires,coil,carb kit,starter,alt,gaskets) are the same as a 360 pickup for that year. Spark plugs are a colder range (Champion F10) than standard automotive plug (Champion F9Y).
With the quality of today's gas if you have plug fouling problems you may what to try the warmer plug.
Old 03-11-2016, 05:30 PM
So I replaced the battery cables and tested the starter as well. Starter was shot. I put a new starter and still only one click. So brand new battery, battery cables, relay, and starter. Turn the key still nothing.
Old 03-11-2016, 07:22 PM
New battery may not be fully charged battery. Put it on a charger overnight, no high amp stuff, don't want to cook it. Make sure you have good ground to engine block. I like to run my ground cable from B- terminal to one of the starter mounting bolts and then make sure there is a good block to frame tie also. The relay needs to have a good ground to work. If you are in doubt as to whether that 42 year old inner fender is providing a good ground path back to the battery, add a piece of 12 gauge wire with some ring terminals on the ends from under one of the relay mounting bolts to a known good ground. got a test light? disconnect the small wire at the relay (the one that comes from the ignition switch) connect it to your test light and then to ground. Turn the key to start, does it light? yes - key switch and wiring is good, no- key switch or wiring is bad.
good luck
Old 03-11-2016, 08:53 PM
firebirdparts's Avatar
firebirdparts firebirdparts is offline
firebirdparts is starting off with a positive reputation.
And use a volt meter. Good advice above. Electricity follows simple rules. The voltage on the system will dip to about 10 volts when you do get it cranking, but while it's not cranking, you should be able to tell easily where the electricity stops. A test light is okay for that too.
Old 03-14-2016, 08:09 PM
So if your inner fender looks anything like this you prolly don't have a very good ground path for your relay to work to good;
Old 03-14-2016, 09:33 PM
Awesome thanks for the help, I'll give it a whirl this weekend
Old 03-18-2016, 02:34 PM
Here are some more pics of the work done already and the wiring. Battery is fully charged, had it on a trickle charger overnight when I first bought it, 750 cold crank amps.
1974 F-600 help! Brownryan90 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-15-2016 06:45 PM
MECHMAN High Output Alternator Installed mattymax 1999 to 2016 Super Duty 13 01-11-2016 09:48 PM
1979 F600 Service Bed w/boom: Curb Weight bm121 1973 - 1979 F-100 & Larger F-Series Trucks 11 12-08-2014 11:58 AM
Issues w/ New Solenoid/Starter Rchess 1967 - 1972 F-100 & Larger F-Series Trucks 13 10-29-2014 10:20 PM
EGR and Exhaust confusion Dave10 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 21 09-29-2014 10:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
