Info on f750?
Info on f750?
Hello, found an older f750 dump truck on a property I built. No papers to be found but an info page glued inside the cab shows a serial or either F75FVN76317 or F75FVA76317 it's a bit hard to tell. The thing is in amazing condition and the engine seems intact. Thinking it may be my next project
Warranty Plate riveted to the left door face below the latch.
Safety Standard Certification Label glued to the B pillar below the striker plate.
VIN also stamped atop the right frame rail, either in front of...and/or partially under the cab.
Compare the VIN on the Warranty Plate to the VIN on the Certification Label to the hidden frame VIN to see if they all match.
F75 = F750 (gas).
F = 391 4V FT engine.
V = Kentucky Truck Assembly Plant.
A76317 = 1976 Numerical Sequence of Assembly, the trucks specific serial number.
K2thO
05-15-2019 12:26 PM
Planejet42
06-15-2015 05:18 AM
