What is the best oil cooler?
OEM oil cooler (updated version) paired with a coolant filter setup is the way to go.
The coolant filter should catch any crud in your system before the oil cooler does.
When i bought my truck, it had a new oil cooler with a delta of 4 at 65mph. My delta climbed to 10 over the course of 5k miles and 4 months. I installed a coolant filter setup and 16k miles later, my delta remains at 10-11 at 65mph. The first 2 filters were full of crud and the 3rd looked decent. The first was changed at 1k miles, the 2nd at 3k and 3rd at 5k. I am currently on my 4th filter. I am getting ready to change the filter again and will post results on filter #4.
I'm up in the air about the so called upgraded cooler.seems both coolers are the same size,but they added another row,wouldn't that make the passages smaller in the new cooler making it easier to clogg up?and if it didn't clogg wouldn't the smaller passages slow coolant down? Maybe I'm over thinking.
I think you might be. The newer OEM cooler is physically (slightly) taller due to the additional row of cooling area. The passages aren't really any larger or smaller, there's just a little more cooling area.
The additional passage will just postpone the inevitable. The newer cooler will still clog, (if you don't take steps to prevent it) it'll just take longer.
The ONLY way to prevent a clogged cooler is to use a cooler that doesn't pass coolant through it. (an AIR:OIL heat exchanger)
If you use the OEM or newer OEM cooler, you'll still have to do extraordinary cooling system maintenance (flushing, the right kind of coolant and/or use a coolant filter.)
If you do not want to do that, your only other choice is the BPD AIR:OIL cooler or other AIR:OIL cooler
Yes........ you can get 1 of a few remotely mounted OEM coolers. But when they plug, you're still going to have to replace them. Try adding up the kit price using a remote system + 2 or 3 OEM coolers (IPR kit is around $1200) and you're approaching what a BPD kit costs (and you only do that once)
This i why I am going to install the BPD kit. (with the "Vernitherm" T-stat) Aircraft engines have been using this type of oil cooling and heat control since the 1940s. It's not rocket science.
I only want to do it once and I don't want to have to do extraordinary cooling system maintenance and then have to worry about it all the time I am driving. (& we shouldn't have to constantly monitor oil & coolant temps and the difference!)
Cheers,
Rick
Does anyone have an actual measurement of the height of the updated OEM oil cooler versus the original oil coolers? It would be nice to confirm if one purchases an updated cooler that it actually is one since there appears to be no other external indicator.
I seem to remember the newer one being slightly "taller". but there's evidently adequate clearance in the valley for it.
But that may not be true. I found the reference comparison. It appears that they may have keep the external dimensions the same, but still added an additional "row" of cooling.
https://www.bulletproofdiesel.com/v/...oil_cooler.pdf
Referring to the above cutaway picture, they clearly were able to make the actual cooling "fin" height slightly higher by making the upper and/or lower housing a tad thinner to accommodate the additional cooling area......
No doubt it's an improvement over the original model because it increases the "clogging area" .......but it doesn't eliminate the clogging......... It evidently just postpones it......
I'm a big fan of BPD's air cooled oil cooler system. When I bought my truck the oil cooler was clogged. I did a ton of research and asked alot of questions on here before I tore into it. I did a coolant flush with Restore and Restore Plus before pulling the clogged oil cooler. I installed a new OEM oil cooler and buttoned everything back up. It was clogged again within 1500 miles. Now I didn't install a coolant filter and I should have cause that may well have kept the new cooler from clogging but hind sight is 20/20. At that point I said heck with this and ordered the BPD system. It was easy to install and works great. Never have to worry about a clogged oil cooler again. And before somebody makes the comment....I know I still need to maintain my coolant system and I will.
Just curious, but how many miles did you have on it when it clogged? I have a 2006 with the original oil cooler. My temps are typically 4 to 6 degrees of each other at normal steady state driving temperature. Currently have about 53K on it. I did have the coolant fluid changed at the dealer when I bought it at around 26K miles. I don't have a coolant filter installed yet but I haven't been worried since my temps track each other so well. I do have one though, just need to get some valves and figure out where I want to install it.
#28
#29
#30
