78-79 Front Dana 60 Sway Bar Links
I have a 75 F-250 4X4 Highboy. I will be installing a 78 Dana 60 front axle assembly soon.
The Dana 60 has a sway bar, but the PO torched the end links when he removed it, so I have only half of the link on each side.
I can't find end links for sale anywhere, only bushing kits.
The end links are like a dog bone, eyelets on each end & offset to clear the leaf springs I think.
Anyone know where to find any or have any for sale. I would need the brackets that mount to the frame also.
Thanks,
Tim
Thanks,
Tim
Here's part of a pic of them on Bill Vista's site. 4th pic down with this write up next to the pic.
"The RCD60 has a high pinion diff - notice how the pinion enters above the centerline of the axle tubes. On an RCD60 the centerline of the pinion is 1-1/8" above the centerline of the axle shafts."
BillaVista.com-Dana 60 Front Axle Bible Tech Article by BillaVista
Would the 78-79 Dana 44 sway bar links be the same?
My sway bar is 1" diameter.
Here's another pic (bottom right) on LMC's site, but the link isn't for sale. Doesn't specify Dana 60 or 44.
Truck Parts and Truck Accessories
Thanks
The f150 4x4 front links in the diagram have an eyelet on the top & a stud on the bottom.
My Dana 60 link has eyelet & eyelet mounting. The sway bar is mounted on the backside of the whole axle assembly, not on the front like the f150.
Thanks for the info about Skyjacker. I may have to get a link through them.
Just seeing if anybody ran into this when they swapped a 78-79 Dana 60 front axle into a 73-77.5 f250 4X4 factory highboy.
Thanks,
Tim
Thanks,
Tim
