What happens when you overfill an AOD
It will aerate the oil and cause you much grief. Instead purchase one of those hand pumps and pull 16oz of oil from the dipstick tube prior to adding the new stuff. Personally, I'd drain the transmission and change the filter - but I realize this may exceed the scope of your project plan.
I realize I did this backwards, but I already drained the pan and changed the filter. I didn't know about this flush stuff then or I would have added it first.
When its cold the engine revs up to around 3,000 before it shifts gears. When the truck warms up it shifts better. I was hoping if I could get rid of some varnish and sludge it would work better.
GResiel, I put the Trans Tune in, took it for about a 10 mile drive and the AOD is shifting up through the gears just fine now. The $6.00 for TransTune sure beats the $1588.00 that Mr Transmission wanted to charge me.
I checked the fluid when I got back. Low and behold, now it's overfilled. Got the pump that you talked about from Advanced Auto for $9.98 and it worked really great. Thanks.
Now if I could just get the transmission to downshift out of OD when I stomp on it, I'd be one happy Ford lover. I'm going to let the TransTune work a little more and if it don't fix itself, I'm going to try to adjust the TV cable.
On edit ======================
You remember from Dune that the hero's name was a wierding name or something like that, and it destroyed things just by saying it? Looks like your name is a smiley face name. How wierd is that?
Byoung Oh
1999 to 2016 Super Duty
03-23-2016 07:20 AM
351Cleveland C4
09-18-2015 06:56 PM
tk1251k
10-25-2010 07:14 PM
bdonalds
13
07-02-2008 10:23 PM
03, aod, case, differential, explorer, f350, ford, overfill, overfilled, overfilling, transfer, transmission
