Engine Knock...
Old 03-05-2016, 10:20 AM
firebus's Avatar
firebus
firebus is offline
Engine Knock...
I have a knock ! (hoping its just an injector)
No engine light, No drivability issues 190k
Not there at start up, not there right after a drive. any thoughts?
Thanks!
Old 03-05-2016, 01:21 PM
lynnmor's Avatar
lynnmor
lynnmor is offline
I've had a louder engine with a dose of low cetane fuel. Yours sounds like one cylinder only, but you might try some cetane booster. Hope you don't have a big expense coming up.
Old 03-05-2016, 01:59 PM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
sounds like on the passenger side bank. You could get the dealer to test the injectors for probably a diagnostic fee.
Old 03-05-2016, 02:25 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
That definitely sounds like a knock. A power balance test would be start, to be followed by killing cylinders individually to isolate the problem cylinder(s).
Old 03-05-2016, 03:01 PM
firebus's Avatar
firebus
firebus is offline
Thanks guys. What I find strange is that it doesn't always do it. Seems only if it idles for a bit?
Power balance test. This is something like a compression test for diesels? (sorry, kind of lost with diesels..)
Would a dealer do this? or do I need to find an independent?
I just wish that there was a dealer around here that I could trust...
Old 03-05-2016, 04:01 PM
senix's Avatar
senix
senix is online now
dealer can do it. With all the computers and electronics that is how it is done now.
Old 03-05-2016, 04:23 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
Yes, that is a test using IDS (Ford Dealership Scan Tool). Since you don't mention any roughness to go along with your knock, it may be a little difficult to pinpoint. If it's any consolation, I have only replaced ONE engine in the five years this engine has been in production. The 6.0L and 6.4L on the other hand......
Old 03-05-2016, 04:37 PM
firebus's Avatar
firebus
firebus is offline
Got it... M-Chan, I wonder if I should just come to you? I am not too far.. I am in Niagara.
Correct though, the truck runs great! Lots of power, super smooth
Old 03-06-2016, 04:08 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
I don't have a problem connecting my IDS to run the test described (for a fee of course). But Randy Barkwill at the Ford dealer local to you should be able to look after you, if it's inconvenient for you to drive up to my neck of the woods.
I do like to venture to Clifton Hill in Niagara on the weekends actually, so if I find myself coming that way, I could perhaps stop off to run a couple of tests the next time.
Old 03-06-2016, 09:33 PM
firebus's Avatar
firebus
firebus is offline
I have heard of Randy. I just don't like the dealership he moved to, but more important that I get a good Tech. so I could live with it..
But yeah, feel free to PM me if you are heading this way, that could work too.. I am right near the QEW
Thanks
Old 03-07-2016, 08:04 PM
Big-Foot's Avatar
Big-Foot
Big-Foot is offline
I would look for a broken or loose accessory bracket or pulley.. It's a knock and metallic, but with no loss of power or oil pressure, you may be getting lucky...
Old 03-09-2016, 05:30 AM
firebus's Avatar
firebus
firebus is offline
UPDATE: So I brought it to dealer and of course there was no knock.. Went back the next day, and we could hear it, so as it turns out it was an injector. Going in for injector number 2. will update.. Thanks for the insight guys..
Old 03-09-2016, 06:18 AM
senix's Avatar
senix
senix is online now
Easy fix! Be sure the dealer posts the new injector info where the old ones were.
Old 03-09-2016, 07:11 AM
firebus's Avatar
firebus
firebus is offline
Oh, where they are listed on the engine? Yeah, I wonder if there is a decal to go over the old one.?
Anyway, lets hope that this is all I need.. Wish I had a warranty right about now. lol
Old 03-09-2016, 08:42 AM
senix's Avatar
senix
senix is online now
They are listed on the CCV breather on the drivers side valve cover. Rear of the motor.
Quick Reply: Engine Knock...
