Tire Carrier Parts Availability?
In between when my 89 rolled off the assembly line and the time I got it, someone removed the tire carrier. All the holes and such are still there and I've managed to piece together a nearly complete 89 carrier to put back on. However, my problem is this: I don't have the latching/locking block that bolts to the tailgate. I think Ford calls this the striker - are these still available somewhere? I don't seem to be able to find a striker part number online. The closest to it that I can find is the one off the 90-96 trucks - is this the same?
Thanks in advance.
Thanks in advance.
Okay, I think I need to restate this.
1. I have a Bronco that came from the factory with a tire carrier. Someone removed the external tire carrier from the truck and never replaced it. The hoies, braces and bolts were all still in the truck when I got it.
2. I have managed to get not one but two 87-91 tire carriers. They are almost complete except for one part - the external support that bolts to the tailgate. This is part number 8 in the below diagram; Ford seems to call it a striker.
3. I'm asking whether I can use the external support from a 92-96 Bronco as I have not been able to find one from an 87-91. I have lines on a couple of 92-96 supports but if they don't work I won't be able to return them.
4. Alternately, if they don't interchange, I'm looking for a part number for the 87-91 support so I can try to track one down.
Hope that clears up what information I'm looking for. Again, thanks in advance.
Edit: I found a reference that seems to indicate the original 80-87 striker had a part number of EOTZ 1469-A and that it was replaced by F2TZ1469A. This referencealso seems to indicate that the 88-89 trucks used a different part number of E8TZ 1469-A and was replaced by "Mat 92000". Anyone have any idea what a Mat 92000 is and if the above information is correct?
