'80-'86 Push bar mounting
Rusty S, this will not answer your question regarding a deeper square, but when mounting a front bumper, I found that the original bolts are capped and sometimes difficult to obtain in a short time. Our local building supply store carries stainless steel carriage bolts which worked just fine. They come in different lengths and the head can be polished and does not look bad.
Thanks for the reply, I might do the carriage bolt route. I just am not sure if its smart to bolt the bumper down without the bolt actually holding square in the bumper hole. Be afraid of moving around.
Besides that, it is safe now to show the one I bought, the link below is the one I purchased. Its brand new in the box made by Rally. Paid quite a bit for it but considering no one makes them anymore and its hard to even find a used one on Esteal, I paid none the less for it.
http://www.ebay.com/itm/7380-rally-grill-guard-80-86-ford-full-size-pickup-and-bronco-push-bar-/262316231867?nma=true&si=8DSFdAxDgTjmEZS3xbhT4oIAzN4%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
That's good to know, I will take a look when this bar comes in see how thick the mounting flange is and see how deep of a square I will need to engage the bumper. If not I will have to figure something out.
Hopefully some that have mounted these before can give their two cents on how they mounted.
So far I will probably keep the original bolts nothing is wrong with them just doubt they will be long enough. I will probably go with carriage bolts as Lowes sells some stainless steel ones I could try to polish up.
The square part of the bolt doesn't need to reach the bumper, as the mounting pad of the grill guard will have a square cut hole. The square part is only needed to prevent the bolt from spinning, while tightening/loosening the nut. Once tight, the square serves no purpose, much like the hex head of a regular bolt.
Truthfully, the mounting pads on the guard are MUCH stronger than the bumper, and less likely to "round out" if they are being removed many years after installation......
The OEM bolts will work just fine, provided the heads don't round off when removed from the bumper.
I can't see the pic, as the link goes to the "auction ended" page, rather than showing what the item is/was.
The real factory/accessory guards have square cut holes, and used to OEM bolts. Once tight, the bumper is sandwiched between the guard and frame, and will not move without a considerable amount of force. It'll bend long before it'll move, if properly tightened..........
Thanks, they do. I originally wanted a flat black powder coated one as once the truck is painted and finished I was going to do the LMC chrome treatment on the front end vs the silver painted grill. But all I found was this chrome one. Hope its not too much chrome down the line. If it is I guess I could always have it stripped down and powder coated.
I cant tell but in the photo it appears to have flat bars welded on for mounting lights. I hope so cause that would save me money from buying those rubber clamp on mounts so I don't have to drill the tube.
Besides that I was looking at these bumper bolts just to add some character.
http://www.ebay.com/itm/1947-1948-1950-1951-1952-1953-Chevy-TRUCK-CHROME-bumper-Bolts-High-Dome-10-pc/330388768166?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20131017132637%26meid%3Ddc931ce05f5042d4a1ed584b90bb8356%26pid%3D100033%26rk%3D1%26rkt%3D4%26mehot%3Dpp%26sd%3D330388768166
I know they are listed Chevy/GMC truck, but the high dome would give a unique look.
Stainless is not as strong as a Grade 5 but will do as long as you don't use it to push or pull ANYTHING.
The Rally you got needs to be assembled?
Since not already welded it is typically on the weak side, As said, don't push or pull anything with it. Under $150 is quite reasonable, and looks Great!
That is why is just "flash mounts" to the face of the bumper and does not wrap around to the frame.
