My cheapskate fix to finding a turbo drain grommet
Here is my answer to the grommet problem if you can weld, and don't want to order and wait on a dsl00143. Go to the hardware store and find a 3/4" carbon steel pipe coupler that fits snuggly in the grommet. Then cut off the small end of the pedestal that goes into the grommet cut the coupler the same length and weld it on where you cut off the other piec,e and you can use a n/a CDR grommet with a factory/ats turbo for less than $2.
60RatRod
85
07-04-2010 06:19 PM
PaysonPSD
32
06-29-2010 10:35 PM
