Alternator/generator light dimly lit once truck is started
Good evening all,
1966 f100 352, bone stock.
As of today, when the truck is started and driven the generator/alternator light in the dash stays dimly lit, very dim.
I went ahead and pulled the negative battery terminal while running and truck stays on, so thats good.
Would the dim light mean a current draw of some sorts?
Belt is tight.
Had alternator tested 3 times recently and is good.
Starter solenoid is new.
Starter is new.
Any ideas what to check?
Thanks,
Aaron
Belt is tight.
Starter is new.
Thanks,
Aaron
Check your grounds and regulator connector. Just went through this. Clean the mounting surface of the regulator and add a dab of dielectric grease. Next, pull the regulator connector and spray with contact cleaner. Make sure the connector is a snug fit.
Check your battery ground and make sure it's good and clean as well.
Everything looks perfect, except the dimly lit part. Hm. Maybe for grins, connect a heavy jumper wire from negative battery post to a clean, unpainted spot on the alternator case. Measure charge voltages again, see if charging voltages go up (or light goes out) Try same on positive side too.
Sure seems like a fault in the alternator of some kind though. Gotta be. Maybe a diode? There are six total. Should be a way to test for backfeeding or an AC component over the DC voltage. The shop manual I have has all the different resistance tests, regulator tests, but doesn't really mention the alternator dash light itself, as part of the troubleshooting.
I think after all your tests and work done that Tedster9 is right about one of the diodes in the trio is/has failed.
We had a dedicated charge rate tester with no gauge, just 4 lights. Undercharge, Normal, Overcharge, and Diode. If the diode light light came on we replaced the Alternator.
Might a system tester at an Auto parts store that will come out the door to test your vehicle have a Diode test on it, I don't know but worth asking. Or online search of how to test Diodes in an alternator like this.
There are usually 3 diodes in and alternator and a failure of one may still allow the alt to charge, but failure is looming
Diverdan0430
06-19-2017 02:30 PM
robert
02-28-2016 05:57 PM
RockChucker30
08-10-2015 10:36 AM
