C2AW4210B 3.50 9" fitment
Need to slightly lower rear end gear ratio. My '68 F100 2wd 9" currently has the OE 3.25 gears. Found a set of Ford 3.50 gears, C2AW4210B, that look pretty good with minimal pitting.
Will the 3.50 gears drop in without mods?
My knowledge says so, but would like to verify.
Thanks.
Already have Oregon Performance low gear kit. I think going 3.70 might be slightly much, especially here with the real world hiway speeds of SoCal. Just needing a little bit more.
Sorry I left those details out earlier.
*Ford C6 Low Gear Planetary Set C-6 Automatic Transmission Lower Gears Lincoln Mercury Kit: Oregon Performance Transmission - Rebuild Parts for 700R4 4L60E 4L80E E4OD 4R100 47RE 48RE & More
My '66 has a 240 in it and had 3.50 rear gears before the pinion broke some teeth. I put in another rear end with 3.00 gears. The 240 liked the 3.50 gears better. I use it as a daily. I spend more time in 2nd gear at higher rpms now. For mostly in town driving, my mpg's dropped from16+, to 13+. Handles 65 on the freeway much nicer. Also, starting off, it's a real dog. 235/75/R15 tires, and three on the tree.
Thanks.
The following users liked this post:
If swapping gears, normally the carrier's change at the 3:73 mark.
If wishing for 4:10's, then you'd have to obtain another carrier assembly. I wouldn't recommend a ring gear shim.
Ok, so I was running 3:50 gears with 255-16 tires behind a 300-six and NP435 trans. way too high geared for my hilly terrain.
After about 4-years, I swapped to 4:10's which work great, except for high-speed expressway travel.
Food for thought: I'm running and have been since 2004, a mis-matched ring and pinion in my Dana 60 rear w/ no problems.
chipper
01-10-2006 07:12 PM
