Rubber Roof Repairs
on
Rubber Roof Repairs
I just picked up my '06 Jayflight on Friday. Didn't have a chance to look at the roof before I bought it as it was in a storage yard. There were no signs though inside of any leaks. I finally climbed up on the roof on Sunday and was pleasantly surprised how good it looks considering we are in the desert. I did notice three minor issues though and considering my last trailer had an aluminum roof I wanted to be sure I am approaching this correctly.
1 - The front edge where the trim is between the aluminum and the rubber roof it appears the dicor is starting to crack a bit. I was just planning on putting new dicor on this. Should I remove any of the old stuff or just put another layer on?
2 - It appears a tree might of skipped along the drivers side edge up front. Doesn't look like it penetrated all the way through, just left little cuts in the rubber. I was just planning on covering this with a strip of Eternabond which is already on order.
3 - The skylight over the shower is cracked like it was hit with something. From what I understand I should just carefully remove it. Clean the roof of old sealant best I can without damaging it, and install a new skylight with a bead of dicor (or sealant recommended by the skylight manufacturer) and then another layer on top also covering the screws. My only concern here is if I should use any chemical cleaners, I've already read that mineral spirits can damage the roof.
In regards to the skylight, you can use butyl tape between the skylight plastic and the rubber surface of the roof. Once you have the skylight secured to the trailer, use some self leveling Dicor and don't be afraid to use a lot.
The front edge, just clean it very well like Scott said, then if you think the self leveling Dicor may run a bit, you can get non-leveling Dicor for the more vertical sections. Depending on the color of the trailer, you can get matching colors if you are willing to wait a bit.
Eternabond is incredible stuff, you will see what I mean when you get it. Well worth the money.
Eternabond and Dicor are 'standards of the industry'. Acetone (Eternabond's recommendation) or 90% rubbing alcohol cleanup before installing either.
That skylight - I have to say that the Lexan replacement I bought for a past RV that came from here was many times better then the original brittle acrylic piece: Replacement RV Skylights from EZ Tops World Wide Inc.
Then the fact that even with shipping, the replacement was a fair number of bucks cheaper then an acrylic piece from a regular RV supply house. When they say it will ship in 15 business days, that's when it will leave their factory as it will be custom made
on
The skylight I'm ordering comes with SB140 sealant. Should I use that for the first bead between the roof (which is TPO) and skylight, or just use butyl tape or dicor? The one I found for around $90 is Lexan and is darkly tinted. Living in the desert I wanted to avoid anymore heat loading than necessary, especially when boondocking and not able to run the A/C.
HRTKD
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
01-07-2018 01:54 PM
TexasRebel
03-29-2010 05:44 AM
Greywolf
07-16-2008 08:38 PM
