Did Ford make a 77 and earlier supercab 4x4?
I thought the first year was 1975, but wiki says...
Originally Posted by Ford F-Series sixth generation -- wikipedia
For 1974, the F-Series became available in an extended cab for the first time. Dubbed as the "SuperCab", it offered the six-passenger seating of the crew cab in a slightly shorter length. For 1975, the F-150 was introduced; as part of an effort to circumvent upcoming emissions requirements, this truck was designed with a heavier maximum payload (2,275 lb (1,032 kg) when properly equipped) than the F-100. With the half-ton F-100 still in production, the new F-150 was referred to as the "heavy half-ton".
I don't know much about the old extended cabs.
I have only ever seen 2 4x4 versions, the first one I was too young and dumb to ask the owner about, he was a parts supplier for the shop I worked at, it was a short bed, I don't even remember if it was 1/2 or 3/4t.
And then there is this one for sale locally on CL
1978 Ford F250 Super Cab 4x4 - $4500 (Breckenridge)
Every other one I've seen has been 2wd.
The grille is 78/79, so it's possible it was either a body swap or a 4wd conversion.
High Boys are Regular and Crew Cab Styleside/Flareside pickups, or Cab & Chassis (no "back of cab" equipment), but no Super Cab is a High Boy.
1977 F250 from serial number Y20,001 (not a High Boy) is the first F250 4WD Super Cab, has a married transfer case, no in-cab fuel tank.
Everything else: 37 1/2" width between the inner frame rails behind the cab. There were no High Boy Super Cabs.
space6433
12-06-2009 04:36 PM
TheMachfather
08-02-2004 09:58 PM
69crewcab
02-05-2004 11:51 AM
