1948 f6 12v conversion, cluster question
#47
#48
well, mine was connected the same. The shrink tube was covering a connector extending the wire (I cut it too short (off) so had to add more ). My ground to the cluster was undersized but worked as it as readings coming in to all points showed solid 12V, etc.
#4, stop light wire on it, then another for testing lights
#1, there is a heavy red wire wrapping through batt gauge providing power.
what is weird, the voltage reducer didn't start working until I separated the grounds, i.e. unhook from cluster and run #5 ground off to another ground spot??
weird. Will check more tonight if rain holds out. Thanx!
#49
OK.
Your alternator output wire must connect to that stud also. Where is it going now?
What is weird, the voltage reducer didn't start working until I separated the grounds, i.e. unhook from cluster and run #5 ground off to another ground spot??
Clearly you have grounding issues.
OK.
#50
#51
#52
#1, I was instructed to run that wire (single wire alternator) directly to battery (as per mfg instructions).
Ground issues? That's odd. voltage check out on everything but the gauges and voltage reducer. I even took all the gauges out and cleaned all contacts. If I touch the cluster mount hole that the black wire runs to from the chassis, I can touch all the other connections and get good readings...
My ground is on the engine (main battery wire), and the smaller one directly to frame.
#53
#54
#55
#56
Connecting to the circuit breaker stud as indicated will provide the same electrical path as connecting to the battery, except that your ammeter will work. Just like Ross said.
The ground wire between the engine and battery should be of the same gauge. The ground wire between the engine/battery and chassis should be a minimum of 4 gauge. The ground wire between the chassis and cab should be a minimum of 6 gauge. Remember that these ground wires carry the cumulative return path current for everything.
#57
#1, I've always read to connect it directly to starter relay or to battery (mfg instructions). You're suggesting going to the cluster circuit breaker?
Ground issue: ok, makes sense but those gauges are quite large. I will need to go buy some ground cables at my local auto parts store. But power isn't that large, the return off the alternator isn't much more than 10-12 gauge I think.
do I still need a ground cable going to cab, and if so where to connect?
Thanx!
Thanx!
#58
How many amps is your alternator rated for? Usually a minimum of 65 amps, as high as 100. For that you want a #8 wire. For best results you should run a same-sized wire from the body of the alternator to a good ground (there is usually a threaded hole on the alternator body for this purpose).
If you have minimal accessories, your grounds to the frame can be a #12, with same to the cab. I think MixerMan is thinking in terms of 6V? You can ground the cab at the bolt hole where the voltage regulator used to mount.
Like has been pointed out, you can connect the alternator output to the starter solenoid or the battery itself, it will work fine, but your ammeter will only show the current being used, i.e., a constant discharge.
#59
Great, thanx for the advice and tips everyone. As for the wire, I was using the wire that came with the alternator, I believe it's 10 gauge. And they suggested no ground wire unless no ground contact could be made. I believe it has a pretty solid ground off the engine, but I'll validate that.
#60
