2006 radio blackout
Old 02-28-2016, 10:55 PM
cbx's Avatar
cbx
cbx is offline
2006 radio blackout
Am I the only one experiencing radio display blackout? I have a 2006 Explorer Sport Trak. the radio display goes blank and stays blank. Do I have to replace the whole unit or is there a fix?
Old 02-29-2016, 07:04 AM
shorod's Avatar
shorod
shorod is online now
If the system continues to work fine, only the display stops displaying, it might be as simple of a fix as a bad solder joint or maybe an electrolytic capacitor that has failed. If you're good with some test equipment, hand tools, and a soldering iron it may be something you can fix. It may be something an electronics repair shop can fix (although those are becoming difficult to find). Otherwise you're looking at replacing the unit. Going aftermarket may be the most cost effective method if you opt to replace.
-Rod
Old 03-04-2016, 10:09 PM
redfury's Avatar
redfury
redfury is offline
When it goes out, do you have any luck by adjusting the dash lights with the dimmer? Could be a weak connection or possibly a pin in the connector that is slightly pushed out of the socket.
hotnanas
1999 to 2016 Super Duty
10-31-2008 11:35 AM
1950t
07-23-2007 02:25 PM
mike3000
05-15-2006 09:47 PM
piezpiedpy
10-09-2005 10:46 PM
Quick Reply: 2006 radio blackout
