Pitman arm removal suggestions
Old 02-28-2016, 05:20 PM
Seanosu's Avatar
Seanosu
Seanosu is offline
I have installed a 4"" lift on my truck. The only thing left is the pitman arm. I have currently broke to removal tools. Any suggestions to get this thing off ?
Old 02-28-2016, 05:26 PM
MI02SVT's Avatar
MI02SVT
MI02SVT is offline
Penetrating oil over night put your puller on tighten down on it smack the pitman arm where you can shouldn't have to hit that hard lather rinse repeat
Old 02-28-2016, 05:28 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,180 Likes on 811 Posts
If all fails heat it enough for it to break loose just be careful with the shaft seal.
Seanosu's Avatar
Seanosu
Seanosu is offline
Will do. Thanks for the advice.
Old 02-28-2016, 05:30 PM
Seanosu's Avatar
Seanosu
Seanosu is offline
Using heat is my last resort. I was worried about melting the seals. I'll let it soak and drink another beer.
Old 02-28-2016, 07:03 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
I had to remove a press on bearing from inside my baler last year and didn't want to use torches for fear of a fire. I ended up putting the puller on and heating the bearing with a heat gun, it took a while, then hitting the shafts with one of those dust off cans for computers. If you flip the can upside down you get the liquid co2 which cools it down in a hurry. Pope's off easy after that
Old 02-28-2016, 07:08 PM
Seanosu's Avatar
Seanosu
Seanosu is offline
I'll try that if the overnight soak fails. Thanks for the info.
Old 02-28-2016, 09:48 PM
mechmagcn's Avatar
mechmagcn
mechmagcn is offline
Hold a 4lb. shop hammer against one side and hit the other side with another one, this'll usually make them pop off. Leave the nut loosely on the shaft in case of a missed swing.
Old 02-29-2016, 03:24 AM
Bob_T's Avatar
Bob_T
Bob_T is offline
I think most auto parts stores will loan you a puller. You have to put down a deposit equal to the cost of the puller and you get it back when you return the puller. You have to be careful removing a Pitman arm as you can damage the steering box by hammering or too much heat.
Old 02-29-2016, 11:34 AM
Seanosu's Avatar
Seanosu
Seanosu is offline
Finally it came off ! Thanks everybody for your suggestions and input. I appreciate it.
2001SuperDuty
1999 to 2016 Super Duty
28
01-31-2019 01:12 AM
DaytonaTunnel
08-18-2014 10:28 PM
sdg0080
1978 - 1996 Big Bronco
10-05-2010 11:15 AM
bmacky14
06-22-2009 08:41 AM
duback66
12-15-2007 08:15 PM
Quick Reply: Pitman arm removal suggestions
