Crank no spark
Crank no spark
So I have read many of these threads on the issue and I have gone through testing procedures, but I'm still having the same results. I have replaced cap, rotor, plugs, wires, coil, pick up sensor, and the icm. What could I be missing the truck is a 90 F350 cclwb srw 460 with the E4OD. By testing I mean that first I started at the spark plug and got no spark, tested the wires no spark, tested cap and rotor, tested to see if the coil wire would shoot to the cap, tested coil for ohms .3-1 got .9. Did the LED light connected to the battery and icm, icm tested bad replaced icm and now I'm at a loss.
I have steady power to the coil when I crank it drops to about 9.7 from almost 12 volts. I have not unplugged the computer nor have I considered doing so is there a reason this might help? I am starting to feel like this icm may also be faulty thank you for your input I'll try unplugging the computer.
You unplug the computer to see if the computer is stopping the spark.
You leave it unplugged while cranking and testing for spark.
You also do not plug it back in until you have spark while cranking.
Also with the computer unplugged the injectors will not fire so you will not flood the engine with fuel.
Then I would make sure you have a good PCM/Body ground at the radiator support passenger side hooked to the NEG post of the battery.
In other words make sure pins 40 & 60 pf the PCM plug have a good ground.
Also make sure the PCM has power on pins #1, 37 & 57 with the key in the on/run position.
