4r100 getting hot
Quick questions: Does this truck have a tuner on it?? Is this truck jacked up / lifted with huge tires & stock axle gear ratios??? These things can easily overheat a transmission STUPID fast!!
The next largest amount of heat generated in a transmission is from the shear fluid force that occurs inside of the torque converter. I would dis-connect both transmission cooler lines to inspect the cooling circuit for a blockage in the lines or in the radiator mounted cooler, or in the aux. cooler. , then run rubber hoses to a 5-gallon bucket & start the truck. Do you get good fluid flow from those lines? If so, re-connect the line that fluid was coming out of. Then re-inspect the return cooler line for proper flow. Doing this procedure, shows you what the cooler pressure line should be & what the pressure looks like as it comes back from both outside mounted coolers. Keep the fluid topped off during this testing. Keep in mind that doing this test will be cheaper than replacing the transmission, even just once! If there is not much flow, then there is a restriction in one of the coolers or the steel line itself. If the flow appears to be good, then replace the torque converter asap. I'd replace it, I'd replace that right away, first.
