vent window assembly.
Yes, 73-79 same same. You will have to remove the long division bar with the vent window frame assembly.
If you are patient, you can leave the glass in the door. Safer to change the complete assembly, because the pin that holds the lock lever on is a PITA to get out, and you can break the stud off. Just in case youare thinking about just changing the locking lever.
James88f150/65f100
05-21-2020 12:20 PM
carnut122
12-11-2010 07:47 PM
