IPR problem i think
IPR problem i think
I have a 1998 international rollback , motor is stamped 1997 . I cut the truck off 45 minutes later went to restart , engine turned over and no start so I was told by a local shop replace the cam sensor so I did and still nothing then someone said clean the ipr so I did still nothing . another told me I got a bad cam sensor so I went this time to dealership for it , put in now truck starts runs about 20 seconds and sounds like it coming apart , any help would be greatly appreciated . Thanks
Check the fuel filter and make sure it is not gummed up. You can check fuel pressure with a regular tire gauge. There is a shrader valve on the drivers side of the bowl. I think it is 20psi while cranking and a minimum of 40 while idling. Closer to 50 is better but it will run at 40.
Fuel pressure is not affected by the IPR.
Hotrod19
07-26-2016 11:40 AM
12 pointer
08-24-2013 09:08 AM
1310monster
06-02-2013 09:16 AM
spicolas
1999 to 2016 Super Duty
03-15-2013 04:07 PM
