RC01 check valve
Just in case you don't know what this is, it's the installation of a check valve in the hydraulic brake line in order to maintain a slight pressure against the brake cylinder cups in the Girling brake system.
I have 1 cylinder with a slight drip and would consider trying this if I could get some confirmation that it works. It's about $75.
Scroll down about 2/3s of the page. Says some leakage is "acceptable". (?)
http://www.bepco.biz/sites/default/f...cas%20Book.pdf
L-G discussion. Don't eat while reading:
How does the parking brake in a 90 F600 with hydraulic brakes work? - Diesel Forum - TheDieselStop.com
Found them on ebay under MBI RH01K
for get this $25 Oreillys wants $80 for the same thing.
The reason for this particular model is that it is sized to replace the barrel connector in the hydraulic line so you don't have to reroute or bend lines.
It also includes a bracket to bolt to the frame for safety.
Oldbluer
29
06-15-2017 05:35 PM
Clefox4
03-27-2015 09:15 PM
chriskot
04-01-2009 08:19 AM
MustangGT221
02-01-2006 06:08 PM
