Opinions on adding 9"drain plug (size)
Jim,
I am not sure if this tool would work for you or not. You would need to pump it like a bicycle tire pump. It comes with three different size tubes. And the gear oil would have to be HOT.
I bought one several years ago and I can tell you it has come in extremely handy, changing the oil in the power steering pump, removing the brake fluid from a master cylinder, or changing the oil in the lawn mower. As long as the oil is hot and you are patient it is a great tool. One cool thing if you start with a clean canister you know exactly how much oil you have removed, so you know just how much to put back. Save on MityVac 7400 at ToolTopia.com
Best of luck to you.
B
B
BII Plow Truck
2017+ Super Duty
10-26-2017 07:14 PM
AussieDog
12-31-2001 07:47 PM
