52 F1 215 backfiring cold...
#35
Well, well, well.
While waiting for the reman carburetor to show up, I replaced the sooted spark plugs, and converted my leaking oil bath air cleaner to accept a common K+N filter I had in house, made the distributor advance line in steel.
The carburetor showed up today- bolted it on and - woohoo!
Runs great, sounds great, drives great.
I hate topics that dead end- so long story short - the symptoms I had were all due to internal carburetor problems.
I wish I hadn't wasted all the time with checking everything else possible, but that's what I get for being a cheap Yankee, and I learned a few things along the way.
Thanks to all for your suggestions and help.
#36
Yep the "spare" carb fixed mine but now you need to tear your's down and see what caused the issue so I can fix my original . If you had the same symptoms as mine, which it sounds like you did, it's a pretty scary backfire almost to the point wondering if the carb blew off the top of the intake!
#37
#38
215 vacuum and ignition
I had idle problems with low power. Being an old old car guy, I checked e erything like you especially vacuum leaks. No luck. Problem was intake manifold bolt were loose. Twice I have had to tighten them up. Point is, not first place one looks for a vacuum leak. Every oil change I check them . Not too many of us left running stock 215's. Only original once. Frank (new to site)
#39
#40
F1-5288 - I love the 215, well most of the time anyway... Trying to keep my truck as original as possible.
CBeav- Interested to hear your theory. My thinking is that in the cold weather- backfiring through the carb. blew the diaphragm for the power valve. Lots of unburned fuel causing the afterfiring.
Old red 1986
15
04-07-2015 11:09 AM
gruveb
11-05-2002 08:29 PM
