1951 F1 disc conversion from Speedway Motors
I just finished installing the disk kit from Speedway, the only issue was the bearing adapters that "press on" the spindle slid on with no effort and the bearing went on tight.....I ended up tack welding the adapter to the spindle and polishing the outer surfice so the bearing would slide on easier. Other than that it worked out well. I also upgraded to a power booster/master brake combo that the sell. So far so good.
1948-1956 Ford Half Ton Deluxe Disc Brake Kit, 5 x 5-1/2 Inch - Free Shipping @ Speedway Motors
With the way things are going, It will probably be April before I get around to installing it.
I bought the kit sold by speedway.
Thank you
I've been eyeballing this adapter: https://www.bobdrake.com/FordItem.aspx?Item=EC-410 It doesn't say it will work with our trucks. But from what I can tell, the trucks used the same stock master as the cars.
I'm probably not the best source for advice on this. I have relatively little experience with braking systems. There are others on here that have a lot more knowledge in this area than me.
