After auxillary tank added, truck runs then dies out.
Hello guys, new to THIS forum but not to FTE.
I bought a 2003 F550 Super Duty 4WD, cab and chassis truck. It has a 7.3 TD. Real nice truck. I bought it to turn it into a wrecker. I removed the factory fuel tank (was behind the real axle inside the frame rails.) I installed a 50 gallon aluminum tank behind the cab on the frame rails. The rear tank has to be removed for the wheel lift. Any way I have everything installed and now the truck dies out after a few minutes. It starts up fine then dies out like its starving for fuel. The tank I installed has a sump pickup (tank came off a freightliner, so its not some home made thing I just welded up in the garage)
Any ideas? I was thinking about installing an auxiliary lift pump as the auxiliary tank is a bit higher than the factory tank, but I want to solve the issue not throw parts at it.
I thought at first injectors but it runs perfect after I prime it so my guess is its not the injectors.
No idea, probably depends on which point in the system you are checking the pressure, but just for determining if it's running out of fuel, it doesn't really matter. You'll get a 'high' pressure right off the bat, then watch what happens, if it just slowly goes down, or if it stays at that pressure for some time, then drops. Or it doesn't drop at all.
I checked the pressure at the pump and i get 68psi. I have not checked the pressure at the filter yet becuase the cheap horror fright pressure tester i bought does not have an adapter to will fit the filter bowl. I will have to go to lowes or ace to buy an adapter. I will report tomorrow the pressure. Thanks again everyone for all of the advice.
it was the fuel pump. Removed the line from the fuel pump and tested pressure there. 70 psi, then today for ****s and giggles i removed the pressure gauge and ran a line right from the pump into a bucket. No volume. I had pressure but no flow. I put on a new pump and truck runs. Thanks everyone for all of the help and advice.
kermmydog
07-24-2013 12:14 AM
Stephanie Adkins
04-15-2012 01:09 PM
1994_F150_302M
09-30-2005 04:18 AM
