Mountain towing with Ecoboost
I have a 2014 F150 w/Ecoboost, MaxTow, and HD package pulling a 6500# wet travel trailer. I've pulled it for a year in Florida and Alabama but no mountain towing yet; so far, towing has been great. I'm planning a trip to Colorado and Utah this summer and have a question. Do most of you put it in tow-haul mode and go on your merry way going up and down steep grades or use the manual shift? I've never used the manual shift so don't know how it works in actual practice. I'm not so much worried about uphill but downhill with curves. Thanks.
Yea I have a 15 max tow and the cool thing about it is when you use tow haul it essentially has a transmission break. So you don't have to worry about manual shifting on down hills to save your breaks. It's actually pretty aggressive. I came out of a 6.7 diesel and it was actually more aggressive at stop lights then the 6.7 in towhaul with a jake brake.
Going up the mountain tow/haul doesn't do much. Going down it does put you in lower gears faster & keeps you there longer which is nice. In hilly areas tow/haul can get annoying with the shifting. In those situations I like normal mode & lock out the gears I don't want.
But that's why it's called just that. It shifts quicker, works as a brake for downhills, and most important...according to the owners manual, keeps the transmission cooler.
Pretty important points.
Ford wouldn't create a towing mode unless they felt the importance and value.
There's all kinds of opinions regarding tow/haul.
If you are on a hilly 2 lane road with a 55mph limit, lock out 6th.
Return trip over the siskiyous at 88 degrees F ambient temp
it overheated and reduced power
Had to reduce speed to 45, turn on the heater and that moved the temp gage just enough below the redline to continue
That is a long hard pull and i chalked it up to pushing too hard up the hill (60 mph)
I have made that trip before with no problems but ambient was about 40 degrees F.
I also limit the transmission to 3rd or 4th on the downhill grade. It handles that well.
Power has never been an issue
I am concerned about the overheating as i am well under the trucks rated tow
Capacity as its built.
On the next two grades i backed off the throttle and turned the heater on as soon as i noticed the gage heading past the halfway point.
Not much on the forums about overheating while towing with the 3.5EB
Truck is in great shape and radiator is clean.
